Directory missing for DJPROAi
Hey @Slak_Jaw ,
Your page describes what you should back up.
I have checked, but the folder does not exist for me:
~/Library/Group Containers/VJXTL73S8G.com.algoriddim.userdata/Library/Application Support/Algoriddim/
Is this normal?
VG DJ Siggi
Hi @DJSIGGI, what OS are you using?
@Slak_Jaw
Sonoma 14.3 (23D56)
Try searching for the djaymedialibrary database file on your Mac. I think this should be contained in a folder called User Data which also contains your MIDI mappings.
