How can I disable shortcuts on Djay pro 2 for Mac?
Hi Renato Novi,
the “Disable Shortcuts” Checkbox is not implemented at the moment.
You can disable all shortcuts like the djay Pro 1 checkbox did by selecting the “User Interface Only (built-in)” Shortcut setting:
