HI
is it posible to display just one deck and use a tablet as a single player ?
Thank you for your mail.
Unfortunately that is not possible at the moment in djay Pro for Windows.
I added your user request to our user request list and wanted to thank you for pointing that out.
Hi Alain,
yes, iPads are more often used to represent one deck than Windows devices.
That is why there is a one deck mode.
Cheers,Lukas E.
hi thanks for your answer
this “great” feature was present in DJay app for ios
regards
