Distributing recordings. How?
I try and load my recordings and cannot as the message reads “No comparable apps found” can you recommend an ap for my iPad? Also followed instructions to open in iTunes and cannot. Please help? Ta.
Dj Badly
Hi Alex,
Do you mean via “Open in…”. You can e.g. use the Dropbox app to upload your recordings to your dropbox folder.
What exactly happens when you try to export your recordings to iTunes on your Mac/PC?
