DJ Connect
Now that the Griffin DJ Connect is apparently no longer being produced, now that I’m finally wanting to take the plunge, how does a guy precue and output in stereo from iPhone or iPad? Is there a replacement product in the works, hopefully one that will allow you to charge your device while using it? Sound output from the Griffin splitter cable ain’t so hot. I put off getting a DJ Connect because I kept hoping they’d release an upgraded version with charging capability. I waited too long.
Nope. I want quality stereo sound output. From Traktor’s website:
“Note: This solution will give you a mono mix of your music files on both the left and right channels of your speakers and headphones.”
Hello,
the Traktor split cable works perfectly with djay pro on iPad…
