DJ Pro 2 and CDJ-400
Hey!
Is there a way to control DJ Pro 2 from 2 Pioneer CDJ-400 and a Mac-computer? USB connection works, so audio goes the right way, but I cannot press play, cue ect. on the Pioneers. I read in an old post that one should create an aggregate device in Audio Midi setup, with 2 Pioneer CDJ-400 and then select aggregate device in prefs of Djay Pro. But I cant figure a way to do that in the lastest version. Does anyone know how it is done?
Thanks for your help in advanced.
Hi @Ittakestwo,
Thanks for joining our Community.
You shouldn’t have to create an Audio MIDI Setup for your CDJ-400. The CDJ-400, as stated in our website, is natively supported on Mac. Follow the steps from page 94 of our user manual to set them up.
Have fun mixing :headphones:
