Any chance we could get the automix options from the Mac version on the iPhone? It’s so much better.
Currently my automix settings on the Mac are:
Mix:
Transition: EQ, Duration: Manuel 16 Bars, Tempo Adjust: Morph.
Song Range:
Start Point: Manuel - 0 Seconds, End Point: Automatic.
Use start and end point are selected. Max song duration: 2mins 30 Seconds.
With these settings it sounds almost as good as any mix I could do live or in Ableton. It would be greatly appreciated if I could get these options on iPhone.
