Hi all,
I’m using DJAY PRO 2
Before using this I had Djay 1.2.1, whereby I was able to create a playlist and select ‘Automix’ The songs would play one after another and mix together nicely
I was able to find other songs, right click on them and add them to the Queue. The Queue would then take priority and play all the added songs, then after this it would revert back to where we broke off from the Playlist
I can’t seem to do this in Djay Pro 2?
I’ve a playlist automixing, I’m adding songs to the Queue and they don’t play?
The only way I can seem to add song is by dragging them directly into the play list
Am i doing something wrong or has this feature just been removed?
Many thanks
