Subject: Preferred Video File Format for Djay Pro
Hello,
I’m currently using Djay Pro for my DJ sets and wanted to know what the preferred video file format is for playing videos within the software. I’m aiming to get the best performance and compatibility, so if anyone has any recommendations or tips on the optimal format, I’d really appreciate it!
Thanks in advance!
I am on Djay Pro AI version 4.1.7 on my Macbook Pro OS Ver 13.2.1.
Hi @nowstanding, sorry for the delayed response. It looks like your MacBook is running an older OS, which suggests you may have an older computer. We recommend using MP4 format with AAC audio and H.264 video codec for compatibility.
Video quality can impact performance, so we suggest starting with 1080p for the best resolution. If playback is too slow, you can try 720p for faster performance. Testing both resolutions should help determine the best balance between quality and speed. I hope that helps!
