I recently purchased the Pioneer wego4. Is this controller compatible with Algoriddim DJ Pro? If so, what software do I download to make it so??
Hey there,
thank you for your mail.
The WeGo 4 is natively supported by djay Pro for the Mac all you got to do is connect the controller to your Mac and accept the midi mapping dialog.
Cheers,Lukas E.
The WeGo 3 is natively supported as well.
Cheers,Lukas E.
And is Wego3 (not 4) compatible with DJ Pro for Windows?
I bought WEGO4 and it is working well on windows Djay pro.
Just i couldn’t activate “master level” and “mic level” controls
Maybe i am missing something nevertheless could you guide me?
