DJ PRO Cache cleaning
I’ve noticed that when i play a song for the first time, it takes more time compared to a song already loaded once.
This means that DJPRO save a sort of “image” of the song on the HD?
If yes, is it possible to clean the cache and save space on the HD?
Now that is a really good question.
Hi Andrea,
djay is analysing your iTunes and locally stored tracks in the User Meta Data folder.
You can find the folder following this guide:
http://help.algoriddim.com/customer/en/portal/articles/2364148-where-does-djay-pro-store-cue-points-…
link doesn’t exist.
