Hi all.
Could anyone help me with video settings for IPAD and DJay Pro?
I ́ve already tested a LOT of settings, ask for support in algoriddim, but nothing really helps.
Every setting that i test, the DJay Pro crashes and close.
For audio the APP is excelent, but for VIDEO, it ́s useless
I will rate that in apple store!
Hey Map A,
thank you for your post and we are sorry to hear that your app is crashing. Can you contact us right via support@algoriddim.com and tell us at what time the app crashed approximately and also which device and iOS version you are using?
Cheers, Lukas E.
