I Have just got the spin 2, i’m using my mac as a main output and have the headphones set to channels 3-4. after about 2 mins i hear nothing but distortion through the headphones, then nothing. If however, i select the the spin 2 as the main output, everything is fine. But then i have no music coming from my mac speakers. The old spin did not have a problem doing this… any ideas?
You can also avoid this by using your Spin2 for both Main and Pre-Cueing output.
Hi Mick, can you please try the workaround(s) posted above and see if that helps?
the problem is marked solved by somebody not doing their job… MANY MANY MONTHS HAVE PASSED.
FIX IT
using the Spin from Vestax
distorted pre-cueing.
