DJ20GO2 connected to Iphone
Hi Guys
Im new to this community. I wanted some advise … I have a DJ2GO2 and im using apple camera cable to connect/charge phone and power the deck. the speakers are connected via aux too but im getting a flickering/distorted noise we all connected and playing music
Hi @Brem when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency. Thanks!
Hardware Firmware Version:
DJ2GO2 mixer, and im connecting to my iphone 14 pro max . Speakers are Pioneer DM40 and im using an Apple lighting to usb 3 connector
What version of djay and what version of iOS?
ios 17.6.1
dj 5.2.5
Thank you @Brem.
  1. Can you please share some photos of how everything is connected?
  2. Are you using your original Apple charging cable and charger?
Yes i am using orginal. Ofc I will send it here this evening. thank you so much
Sounds good. Have you tried a different Aux cable?
No but when I connect the pioneer dm40’s and use a connecter to my iPhone directly and play music it’s crystal clear though
Have you tried a different USB cable (the black one)?
No what’s it called il buy it off Amazon now
I need to see a picture of both connector ends to tell you what type of cable that is for sure. My guess is Micro-USB to USB-A though.
P.s the aux is the wire direct from the speaker and if I connect speaker to my phone it’s clear so it’s not the aux
Yes it is A cable , it should be coming today on Amazon … fingers crossed
@Slak_Jaw will changing the cable A resolve this matter you reckon ?
It sounds to me like it could be an issue with the cable or issue with the DJ controller. Let’s check 2 more things first though. With the controller connected, can please navigate to the djay Settings>Sound and share a screenshot of this page?
Can please also share a screenshot of the djay Settings>Audio Devices? Thanks!
Make sure your controller is connected and recognized then press Reset to Defaults in the Audio Devices settings.
