Djay 2.1.1 on iOS 6 with iDJ Pro controller
Is anyone out there running Djay v 2.1.1 on the iDJ pro with iOS 6 still installed? If so, are you experiencing any of the issues people who upgraded to iOS 7 are experiencing?
I’m still on version 2.0.2 until I know for sure.
Hi Jerod,
Which issues do you mean exactly? We tested djay 2 with iDJ Pro on both iOS 6 and 7 and didn’t encounter any problems. It seems as if only certain devices or setups are affected.
You can definitely upgrade to 2.1.1 though.
Hi Paul,
Sorry to hear that. What type of cue problems have you encountered exactly?
Thanks for the reply
Knock on wood, twice, but I can report having zero problems with Djay 2 and iDJ Pro under iOS 6, up to v. 2.1.1 (I think that was the number). I had a three-hour gig last weekend and it all went smoothly. I did notice a new 2.1.2 version came out this week but haven’t used it yet with the board.
I must add that I feel the pain of those who have upgraded to iOS 7 and are now in a pickle. TG I resisted the temptation just because I have gigs line up and couldn’t take the risk.
On the other hand, I hope that Apple, Algoriddim and\or Numark issue very soon upgrades that will fix all these nightmares people have with iOS 7. Some folks seem to be jumping ship as a result. For my part, I always hedge and stay current with the competition, just in case . . .
Yes ios6 and djay 2 have major cue problems…on ipad 3…???
Hi Warren…cue from headphones coming out of both speakers…when fader is at any position, so you hear a complete mish mash. The sound then cuts to either one or the other speakers only, its quite random. Its happened on a few occasions and I must note its only happening during a mix, usually a long mix and when the mix is at its loudest, by that i mean when the mix is quite busy and the track is at a louder section. Whether this helps you with anything i dont know? I am running ios 6 on ipad3. Djay 2.2.1. I am looking at a reloop beatpad now, have you had any issues with this and the djay 2 app? if its a software problem? Would not affect any controller you use? Thanks, Paul.
