Can you use the Djay 2 for Android with Pioneer DDJ SB2? As in can you map the midi even if it doesn’t automatically map out of the box? Thanks
You can find all Android ready controllers here:
http://help.algoriddim.com/customer/e…
Hi Oscar,
please note that this is not possible. We are not supporting a midi learning mode for the Android application. This is only possible with djay Pro for the Mac.
http://help.algoriddim.com/customer/en/portal/articles/1741815-which-midi-controllers-are-supported-…
Hi Oscar,
Hi Oscar,
the operating system of your device is the only requirement, you can see the needed os here:
http://help.algoriddim.com/customer/en/portal/articles/579419-how-to-purchase-djay-pro-for-mac-
Thank you
Can you tell me what are the mac computer requirements for your previous versions Djay 4 and Djay 3?
Any new controllers supported for DJay 2 for Android?
We need a pro version for Android too, or at least to be able to edit/upload a midi mapping file. Spotify is good reason to use Djay 2 for Android too, but the higly limited support of hardware makes it much useless for a houseparty. Much more supported for chaper DJ controllers is necessay, because Spotify is mostly usabe at a houseparty, and such people who would use it are not buying pro controllers. I use a Hercules Universal DJ for such occasional cases and find the lack of support for this entry level controller is very sad.
