I am using Djay2 (2.8.4) as well as on my iPad air 2 (IOS 10) and the app is not detecting my WEGO4 controller. I have installed MIDI wrench and cannot see any MIDI signals transferred.
Please advise.
Note - I am using a brand new iPad and WEGO controller both purchased only a couple of days ago.
I wish I could help. I’m having the same problem with my new iPad mini 4 and WeGO 4. Help page says that my mac should not need to download a driver. I’m confused. Did you get any information so far?
I have the same issue with my iPad 5th gen. I have contacted pioneer and they said to uninstall and then reinstall and it should work. It hasn’t worked. How do I fix this?
Same here with ipad new 2017, but works on my iphone x. Reinstalled the app but didn’t worked, I only can get the sound from the controller but everything else doesn’t work((( in settings in MIDI section show no controllers
