this is crazy! i bought a splitter cable to be able to cue my tracks and i enable the feature in the settings menu but i don’t see a cue button in the main screen of the app! is this a bug?
i use the latest djay 2.1 update on a nexus 7 tablet!
Please algoriddim!!!
Hi, I have just recently purchased Dj on Android and I have a Griffin cable but following your instructions above I still get no pre cue output?
Hi Dimitris,
No, this is not a bug. As we don’t want our interface to be overload, there is no extra “Cue button”.
Let me explain how this works instead.
First off,
Open djay and select “Preferences”
Enable “Split Output”
Load a track on both of your decks
Fully switch the Crossfader to one deck
As you’ll notice, the Pre-Cue output is automatically sent for the other deck.
I see! I never thought it would work like this because i am used to blend the tracks with the volume faders but i will learn!
Tnx for the reply!
Hi! I have the same problem in IOS with a Traktor DJ Cable. I switch on the Split Output, but i can;t see the headphone button on the interface of the app (Djay 2 a Djay Pro). Did you fix it?
