After launching algoriddim Spotify search engine keep spinning
uninstall it 2 times and reinstall same thing search engine just keep spinning
Hey Leeroy,
Are you referring to Djay “Pro” 2 on your Mac?
Hey guys thanks did on software update on my MacOS Huigh Sierra version 10.13.3 and that took care off it
Djay 2 is more for android you must purchase djay pro for mac before you do make sure you running 10.9 m. Lion or higher
