Does the new version from 5 onwards use more processing power than Version 4?
I mean the new Fluid Beatgrid and improved stems, are they more processing intensive?
I know that my ipad 9th Gen shows Neural Mix at 100% and would upgrading to an iPad air 5th Gen make Djay 5 work easier?
Hi man. Question…, if your current iPad is running 100% how come you wanna change? I get it though I do like new shiney things.
Yes it is running at 100% but I’m wondering if it’s maxxed out of it’s processing power…
I’m starting to see occasional lagging within the software especially when using Sync and Neural mix at the same time…
Get yourself a new shiney one
