djay AI - config reset to defaults
how can I reset all djay AI config to default. I have several problems that was in previous version and I checked that on new user it doesn’t exist, but it’s still on my user account. I was deleted djay folder in /users/…/music/ on my macOS, removed djay AI app, and reinstall it, but when I open the application it remember all my setting anyway.
Regards
Adrian
Hi @PROsiaq,
Thanks for sharing your question in the community!
So that I can better assist you, could you please answer the following questions:
  1. What Mac model are you using?
  2. What macOS version is running on your device?
  3. What configurations/settings seem to be affected despite uninstalling djay?
Hi @NathanielAlgo
I posted topic about displaying playlists problem - this issue: DJay Pro AI v5.0-5.0.3 Interface colours of selected items, song covers
and even I reset djay configuration using this tip https://help.algoriddim.com/hc/en-us/articles/360014703412-How-do-I-reset-all-djay-settings-back-to-the-original-default-settings
and reinstall the app the problem persist. I think that there is some more information somewhere stored that’s makes the issue. Im using MacBook PRO M2 on Sonoma 14.2.1.
Thank You in advice
