I have downloaded the DJAY app (free) on my android phone, however there isnt an option to sync via bluetooth to the ddj 200? Also is this the only way to use spotify on the ddj 200?
Hi there. Hit the yellow dot top middle, then settings cog then Bluetooth Midi Devices.
You can connect Spotify to djay but only til 1st July where it will disappear from all dj apps, so there isn’t way to use it soon
