is the monitor connection from the dJay cable for iPhone a stereo signal? Is it just the headphones where the monitor is mono to one side and the pre-mix is mono to the other?
thanks!
thanks!
Hi Andy,
Yes, the Griffin DJ cable has “normal” stereo connections.
You will get a binaural signal for master and pre-cueing, so you will hear sound on both speakers connected to the master channel and in both ears of the headphones connected to the pre-cueing channel.
