Hi
I use djay on Chromebook ans it works fine.
Is there a way to plug a midi controller ?
Hi
Have you tried using a USB OTG cable?
We are supporting midi on Chrombook and therefore, every djay 2 Android controller works with Chromebook as well.
You can find all supported controllers on our hardware page:
Thanks for your answer but I mean : is it possible ?
I know you can use a controller with Djay and an Ipad but I don’t know if it works with a chromebook ?
you cant yet… I had to switch to the WeDj appcuz I thought this was compatible and it wasn’twhen I bought the controller cuz if that’s what it said… But I tried and tried
