hj,
I have a ddj wego3 and a tablet Xiaomi Mi pad 4.
according with the information It would bê compatível bit when i load the decks play bit doenst work the música, the “plate” its ok but music doenst work.
All things in controller até ok… The faders knbs and the play and cue Button Works ok.
But the music doenst.
Im using the original cable with otg as recomendei.
Is It really compatible?
The system os a Android 8.1 as recomendei
Please send me a solution.
