Have found an error in regards to enabling the microphone. I currently have my bluetooth headset connected to my macbook and using it as a wireless mic
as you can see it connects fine and i can use to hear the music perfectly, but as soon as i slide the toggle in the microphone section the application crashes
Thought this might have been an over site in regards to the new pro version of the application (as there are always bugs in new software and port over) but tried it on the original version of Djay as well and the same thing happened.
I informed Warren of the crash months ago… so either way you look at it, it’s whatever.
I ordered the new Denon DN-MC6000mk2 yesterday in hopes that it will be easier to map. So again, if you need a denon controller to work with, I am GLAD to send you mine.
Believe it or not, I am your number one fan… but a fan that can’t USE the product does no good to you or me. When the basics are fixed, I will speak highly of this product from the highest mountain top.
