I’m loving the latest update and integration. However, whenever I try to use effects, my channel goes out and I have to turn the effect off, lower my line level fader and bring it back up to get sound. I never get effects. I’m guessing this is a routing issue but no configuration I’ve tried helps. ANy tips would be appreciated.
Thanks for your post. Can you please try to tap “Reset to Defaults” in the Audio Device Setup settings in djay? The ELITE requires a special FX send/return audio setup, and it sounds like that might not be configured correctly for you.
Great to hear! Just for future reference, the same “Reset to Defaults” option is also available on Mac by clicking the disclosure triangle in the lower left corner of the Devices settings.
