Djay for hercules djcontrol instinct
Djay 2 should be compatible with the hercules djcontrol instinct. The app I use it only uses itunes music that you have to buy. So using the hercules djcontrol instinct will be better if it worked with djay 2
Thank you for your post.
We are supporting all natively supported iOS controllers. Therefore, the Hercules Instinct can not be supported.
I agree
