I have recently updated Djay on my iPad which i use on the Numark iDjay pro console. Upon shutting down my iPad and restarting after the update completed, i have not been able to access the library, at all…
I have attempted repeatedly to open the library via the rotary/toggle on the Numark and by using Djay’s on-screen button, only to bear witness to a 1/2 second flash of the library and its contents. The app then closes itself completely and leaves me shaking my head in frustration.
I have not had problems with you’re app before, and highly recommend it to anyone interested in the art of mixing… from amature to advanced.
Please fix this bug, I’m gettin all crankcious without my tunes available to play.
This is already a known issue and our developers are currently working on it.
In many cases it only crashes when loading music from the “artist” tab of the iTunes library, so please try to not load music from the “artist” tab until we have fixed this problem.
We’re very sorry for the inconvenience and kindly ask for patience.
In order to get this problem fixed, we need to know, what exactly is causing the crash. Therefore we kindly ask for your help: Can you sent us the Crash Report to support@algoriddim.com ? It can be generated by following these instructions (Don’t worry, it’s really a straightforward process):http://www.ondemandworld.com/how-to-find-crash-logs/
