Songs that that previously loaded, won’t load. Icon comes up COULD NOT LOAD TRACK. Started after I updated djay app. Please can you help.
Respect
Paul
Respect
Paul
HI Paul,
Which iOS and djay version do you have? What is the exact error message?
Same problem here with iOS 6.0.1/iPhone 5 and latest djay update.
very annoying happens with half of my songs, noticing it just right now…
Here’s some additional info :
Hardware : iPhone 5
iOS : 6.0.1
Djay version : Djay for iPhone 1.6.3
File name of non working songs :
03 Hey Hey (DF’s Attention Dub).m4a
02 Hey Hey (DF’s Attention Vocal Mix).m4a
A video of Djay’s behavior on this link : http://mix.mu/DJAY.MOV
A screenshot is also joined in this post.
I hope it helps you enough to fix this quickly, got gigs coming for the year end !
update :
I fixed this ! I first noticed it didn’t play on the iPod app either.
I first connected on the Mac and tried to sync again several times because sometimes I notice iTunes forgets to sync songs but it didn’t help at all.
Then I went on the iPhone and found there was a list of files added manually on the iPhone. I removed them all. Although the songs that had the issue weren’t part of the list, the problem was fixed after syncing again.
Hi Warren
iOS 6.0 - djay version 1.6
Could not load track
The operation couldn’t be completed. No such file or directory.
THANKS for your help.
Respect
Paul
I have this problem on my iPad. Can you please tell me exactly in detail what you did?
Thanks a lot!!
Hi Warren,
I have the same problem, please help!!
Regards
Manu
