When i use djay with my iphone 5s in my car connected to a nissan connect radio only the left channel is working. The right channel is silent. The fader and balance settings of the nissan connect radio are in netral position. When i use the music app of the iphone both channels are working fine. Any ideas?
Hi Strak,
This is already a known issue. Our developers are currently working on this and will fix it as soon as possible.
In the meantime you can try to enable and disable the split output option in the settings, this helped in some cases.
We are very sorry for this inconvenience and kindly ask for patience.
