Im soon to be getting a new iPad Mini that has come out and i was wondering if the app and Controller, ( IDJ live ) would all work on a iPad Mini. Thanks.
Hi Zach,
djay for iPad also works on an iPad mini.
As for the controllers, they should also work via Lightning to 30pin adapter. Though to make sure, I recommend contacting the manufacturer’s support directly.
Note on iDJ Live: Some controllers are incompatible with iOS 6. So, I recommend directly trying out the device with your new iPad mini before purchasing it.
As already mentioned in the previous reply, djay for iPad also works “natively” on an iPad mini.
Is there an update to this question after a year…has nothing been made for us mini lovers
