Hi @Nubium, can you please provide more details about this issue so the team can try to replicate it? As usual, a screen recording would be very helpful. Thanks!
Thanks for the video @Nubium. This is very helpful. Since the app is crashing, please submit an Official Support Ticket using the procedure below so the engineering team can review your crash reports in more detail.
Open the djay app on your device.
Navigate to Settings>Contact Support.
Fill out the submission form and title your email "ATTN: NATHANIEL – “djay hanging on first page - Community” in the provided subject line.
I’ll consider this community topic solved for now and let the official support team take over from here. Thanks!
Here I am showing that sink is turned off and when you look at the screen, I press play and sync turns on by itself. Wtf!!! I did a hard reset before this gig
Hi @Nubium, I have merged your other topic with this one to keep the conversation with the official support team organized and because these issues are likely related.
Regarding the Sync turning on automatically, is it possible that the Sync buttons on the Mixon 8 are stuck in the On position? There have been many reports of sticky performance pads so this could be a similar issue.
Can you please share a screenshot of your djay Settings>General>SYNC MODE and Settings>General>CROSSFADER FX?
Are you using Crossfader FX?
Are you using Deck 3 and 4 at all? Perhaps Sync is enabled on one of these decks by accident.
About the sink buttons, turning on by themselves. I don’t think it’s a Hardware issue the lights on the sink buttons on the hardware are off sync only turns on exactly when I press play.
The other thing I’ve just noticed is as soon as I load a new track, even when the sinks are off it loads at the same tempo as the old track
I don’t know when I’ll be able to submit that crash report. I’m playing a wedding tomorrow and another gig the day after and I need to use this app. I’ve been quiet late because I haven’t been doing very many gigs and I’ve just come back to all these problems, One thing I will say the seem to happen when I upgraded to iOS 17.5
Looking at your video, I can see that the Crossfader is highlighted in Blue which means Crossfader FX are ON. When CFX is OFF the crossfader will be shown with a White line instead of Blue line.
