Dutchie
1
- Device model: iPad 8th generation MYLD2NF/A 128GB
- Version of operating system: iPad OS 17.3.1
- Version of djay: 5.1.2
- Hardware/controllers used: Hercules DJ Control Inpulse 500
Summary of the issue:
Djay is ignoring done button or cancellation when loading a deck. The next song that will be pressed will be loaded! Even on a protected deck playing!
How to reproduce the issue:
See video attached
PKtheDJ
2
There’s no video attached - just a blurry low res picture.
Dutchie
3
Thought so, I will check If I can upload elsewhere.
Hi @Dutchie, can you please provide full details for your iPad as well?
I was able to reproduce this on my iPad as you’ve described. I’ve gone ahead and forwarded this to the engineering team for further review. Thanks!
Dutchie
7
Hi @Slak_Jaw I have updated the post.
iPad 8th generation MYLD2NF/A 128GB Is that detailed enough?
Hi @Dutchie, the engineering team has fixed this and it will be included in the next djay update. Thanks!
Dutchie
12
Wow that’s fast!
Thanks! I will pull the Movie from Google Drive is that okay?
You’re welcome @Dutchie! Yes, you can remove the video from Google Drive.
system
Closed
14
