Hi all, Is it possible to control Djay on an iPad1 with the m-audio x-session midi controller? Most likely with the camera connection kit?
Hi Chris,
No, this controller is not supported.
Regards
Hi Lucas,
Yes, Vestax Spin is supported with djay for iPad.
But you will still need a special “Split-Cable” for Pre-Cueing.
Please visit the following sites for more information:
What controllers are compatable with djay? Sorry iPad djay ONLY?
Isn’t Vstax spin?
