Djay - Neural Mix EQ will not Double
Hey Team,
Can you please implement allowing Neural Mix EQ to Copy when the Double feature is activated?
Hi @LaidbackFred,
Thanks for the suggestion!
Do you mean when doubling the track onto another deck you would like the current Neural Mix controls (settings/position) from the original deck to carry over to the new deck?
Hey Nathaniel,
Yes, that is the case.
Thank you
