**I don’t know if no one noticed, but djaypro is not accepting any changes made on a playlist stored in Music. In the past, I moved the songs up and down in Music and the changes were updated in djaypro once I turned it off, well, not anymore. Moreover, even if you eliminate a song in a Music playlist, it continues to appear in djaypro as if nothing has been eliminated. This is HORRIBLE because the playlists are static, and you are not able to clean them anymore. Please, tell me you guys didn’t screw up again, and it’s a button I have switch on!
Thanks for the attention, Nathaniel. Here’s the info you’ve asked:
What Mac model are you using?
A: MacBook Pro / Apple M2 - 2022
What version of macOS are you running?
A: macOS Sonoma
Are you using djay v5.2.5?
A: Yes
When you refer to the “Music” source are you instead referring to “local music” or “Apple Music”?
A: Apple Music
Are there any additional details you can give us regarding this issue?
A: I have tried to log off Apple Music in djay and log it on again, refresh the library, but the changes to the Apple Music playlists are still not reflected on djay.
Don’t waste any sleep over it. Case resolved. It looked like a bug was going on with a specific playlist from Apple Music, as when I started shifting songs on the other ones, everything was fine. I basically fooled the machine by moving the first two songs up and down on the bugged playlist and, for some reason, everything was updated. Well, you know what technology is like: You send a message, if the response is not received (for whatever reason), the two apps stay in a limbo, which is broken by stimulating them at some point. That crazy.
