I was trying to use my yamha ag06 to make sure that I can pre cue and I can also have a stereo channel sound from my speaker! I don’t quite understand what happened cuz djay is recognizing it as a MIDI, does that means I can olny use a audio interface instead of a mixer??
I’m not sure why that happens as apparently it is a class compliant device so in theory it should work.
hi
i’ve just tried with my AG03 and yes Djay recognize a midi device BUT it also works as an audio output in Djay. In settings it appears as the master audio output. No pre cueing is possible though.
Regards
Hi @Mister_X,
Thank you for your post!
Would you be able to share a screenshot of your audio configuration with the AG06 plugged in, as well as what other devices you are attempting to use in junction with it?
This will help us gain more insight into this matter!
I’m looking forward to hearing back from you and have a nice day!
Thanq but I have already find a way to pre cue by using a docking station plugged to iPad
