Djay - operating each deck independently
Hello,
Is it possible to operate the decks in Djay completely independently of each other?
If I’m playing on deck 2 and then start deck 1, deck 1 always seems to switch to a BPM related to deck 2, even after resetting the BPM prior to play. This happens irrespective of Sync being switched on/off, and is the same on Mac and iPad.
I just want to run any deck at its own BPM without it changing.
Is that possible?
Hi @pns_soc, welcome to the Community! It sounds like you might have Crossfader FX turned on. Please see below. If it is on, please turn it off and let me know if that helps.
That seems to have fixed it!
What a simple remedy :grinning: - thanks very much!
Excellent! You’re welcome @pns_soc
