djay playlists: CSV to M3U
Some people asked me how I convert djay csv files to a more univerally compatible m3u playlist, so I decided to post my solution here.
The Bad News:
This solution, is not end-user friendly. It’s written in Python, so you have to know, or be willing to learn, how to run the code. I created this in macOS, it should work in Windows. I’m not sure about iOS.
The Good News:
It works. You can quickly produce m3u playlists that are easy to backup and import into other software (like iTunes, Serato, Rekordbox, Virtual DJ, Traktor, MP3Tag etc.).
How It Works:
Give the program a .csv file from djay and it will create an .m3u playlist file. For example:
  • export a djay playlist as hip-hop.csv
  • the code will create an m3u playlist called hip-hop.m3u, that can be dragged directly into iTunes, Serato etc… FYI - double-clicking a .m3u file on a Mac will automatically load it into iTunes.
STEPS TO RUN THE CODE:
  1. Install Python:
    https://www.python.org
  2. Copy/Paste the code into a plain-text file. Give the file a .py extension. For example, createplaylist.py note: I over-documented the code, so you can see what every line does.
# python modules
import os # command line utilities
import csv # file utilties
import urllib.parse # decode URL to File Path
from tkinter import filedialog # graphical interface
# Main Function Definition
def createM3U():
    # Set Files and Directories
    csvFile = filedialog.askopenfilename() # ask user for csv file
    m3uFile = csvFile.rstrip(".csv") + ".m3u" # m3u playlist name
    dirName = os.path.dirname(csvFile) # set export directory
    # Transfer Playlist Data
    with open(csvFile, 'r') as file: # open csv file
        csvData = csv.reader(file, delimiter=',') # get csv data
        with open(m3uFile, 'w') as file: # create m3u file
            header = next(csvData) # skip header row
            for row in csvData: # for each audio track
                # decode URL
                audioTrack = "/" + urllib.parse.unquote(row[6].lstrip('file://')) + "\n"
                file.write(audioTrack) # add track to m3u playlist
    # Show Files to User (only tested on Mac)
    os.system('open ' + dirName)
# Run Main Function
createM3U()
  1. Running The Code
  • Command Line Terminal
    python createplaylist.py
    or python3 createplaylist.py
  • Python Launcher (GUI)
    right-click on the Python file, select Open With > Python Launcher
    pythonlauncher
  • VS Code (IDE)
    For those who are savvy, you can run the python code in an IDE like VS Code.
DJ SET HISTORY
if you just need to export your historical DJ Sets, there is a command in djay Pro that will transfer the DJ Set playlists directly to iTunes (where you can export it as a .m3u file)
Screenshot 2023-08-09 at 10.39.11 AM
Custom Playlists in djay Collection
Unfortunately, for custom playlists in the djay Collection, you have to use the python code in the 1st post…
Nice work on this @Michael_Wisniewski! Thanks for the detailed explanation as well.
Wow wow wow! Amazeballs in Awesomesauce!
