Hello ,
i am using djay pro 1.4.1 and while i am playing songs on it , the cpu’s temperature goes up to 100 Celcium Degrees . Also the the temperature of GPU Die and GPU Proximity goes up to 80 Celcium Degrees which can end up in a damaged motherboard because of high temperatures …as a result the Fan goes to maximum speed …
I stopped using djay pro when this problem appeared…it’s unusable and i can’t risk my macbook pro for this program
Please fix it !
