DJay Pro 1.4.1 Update keeps causing shutdown and wont install properly. Can You send me an external Download link that is Non Mac App Store?
Hi Mark Tapia,
we are very sorry to hear that, can you please give us further information about your setup and macOS version.
Thank you for your follow-up, as you can tell it is in our interest to find the root of the problem as fast as possible,
issue should be treated separately
Please reference the new conversation here: djay 1.4.1 audio issue
Sounds not good, can you contact us via support@algoriddim.com for further help?
Hi Mark Tapia,
my colleagues will do their best in order to help you out. Thank you for emailing us.
Hey Lucas. Howbis your day going? My setup is Late 2008 Macbook Pro 15 OS X El Capitan 11.6.1. I finally got my Macbook to Boot Up and Stay on after installing DJay Pro. Deleted caches and resinstalled OS X 11.6.1. Djay Pro came back and is functioning fine…but can not update at all…gives me corrupt error messages. Ive deleted resinstalled…same issue.
I emailed link attached. No response yet
Still have not been helped out with my issue. I was siggested maybe I have the Djay Pro LE version?? I don’t…
The updated version has created a tinny sound when the music goes out and has not resolved the problem discussed with the creator not just by me but others. I am not impressed. This is an issue I was told would be resolved and it has gotten worse.
