What is going on with Djay nowadays never have a problem with the software until late 2019 or some time early 2020 it’s very laggy cant DJ well with all the lag what is going on??? Also is making my controller the ddj1000 lag.
Thank you for getting in touch. We are sorry to hear about your the issue you are facing.
Could you point out your macOS version and exact device which you are using?
MacBook Pro (15-inch, 2017)
Processor 2.9 GHz Quad-Core Intel Core i7
Memory 16 GB 2133 MHz LPDDR3
Graphics Intel HD Graphics 630 1536 MB
Running macOS Big Sur ver 11.1 also was doing this on macOS Catalina 10.15
Djay Pro Ai ver 3.0.4 and Djay Pro 2 ver 2.2.8
CPU seems to be running high at times when lagging. CPU is up to 50% 60% plus on the djay pro both ai and pro 2 apps. When it comes down to around 20% 30% or less the software works fine but cpu on the app goes up and down for a while and is very laggy when the CPU is up on Djay pro Ai. Every time I started the app CPU is up and the software lags badly
It even has my ddj1000 jog wheels screens lagging if I have it connected.
When running rekordbox CPU is up 50% plus rekordbox doesn’t lag.
