Djay Pro 2 is not working smooth for some reason, and i don’t know what the problem is. what for example happens is, when automixing, the transition happens in chunks, like how you can have low fps in a game. so instead of the fader going smooth from one side to the other, it happens in chunks. I have had this ‘chunking’ problem for a while now, and i would really like this problem to be solved. (this ‘chunking’ also effects things like the time it takes for the menubar to appear)
Hi Neal,
Thank you for your post. Could you please send us an exemplary video of the explained automix transition and send it to us via support@algoriddim.com?
Thank you very much for your feedback.
