When I try and apply a “Date Added” filter to a playlist, djay Pro stalls out and refuses to respond. It’s been doing it every single time since I applied the 8/10/2020 update.
Hi @probablyalfie,
Sorry to hear about the issue you’ve encountered. So we can take a closer look, could you please tell me the following:
Thanks in advance for the additional information.
MBP Retina 15-in Late 2013 running Catalina 10.15.5. djp version is 2.2.4. I’ll be in the My Library tab and when I switch between filtered playlists OR when I try and apply a filter to the playlist I’m currently on, I get a spinning beach ball of death. The program will continue to play any currently running tracks, but the problem occurs even if nothing is loaded into a deck. The program becomes non-responsive and I have to force quit.
Also, the same freezing occurs when I try to analyze my entire library
Hey @probablyalfie,
Thanks for the additional information. Since we haven’t been able to reproduce this issue on our devices here, in order to take a closer look, it would be very helpful to get any generated log output from djay. To do this, could you please follow these steps:
Then, could you please send a message to support@algoriddim.com, attach the .txt document logs, and reference this forum post so our team can further investigate this for you? Hope to hear back from you soon so we can get to the bottom of this.
