DJAY Pro 2 from DJAY Pro 1
I recently purchased DJAY pro 2 and would like to convert all my metadata (Cues, etc.) over from DJAY Pro 1 to the new DJAY pro 2. How do I do that? Thanks!
Hi Cory,
Thank you for getting in contact.
Are both djay versions on the same Mac device?
Cheers
Lukas E
Hi Cory,
After installing djay Pro 2 for the Mac with still having djay Pro 1 installed on the same device, djay Pro 2 will ask you to import your user data.
Cheers,Lukas E.
Yes they are. Same computer and same Mac Device. My thing is I am completely all in on DJAY pro 1 with Cues, customization, etc. I keep getting a notice I need to update my software for my OS so I am forced to switch to DJAY Pro 2 but don’t want to spend the time to re set up my customizations (Cues, etc.) so If I could pull them over it would be great.
It doesn’t. I have it and would like to import the files over. Is there any way to do this manually? Thanks for your help. Should I uninstall Djay Pro 2 and then re-install it? If so How do I do that? Thanks.
Cory
I would also like to know how to do this?
