Hi -
I submitted this issue via email but thought I would add to the forum as well in case there were others experiencing something similar.
I’m using a TC Electronic Desktop Konnekt 6 interface for Audio in/out and a Numark Mixtrack Platinum controller. Currently running MacOS Mojave on a 15” 2017 MacBook Pro.
On the original Djay Pro I’m able to use the Numark for Cueing, and the TC interface for Main output and Mic input:
The exact same configuration in Djay Pro 2 fails - no Mic input is registered at all:
Is there an additional SW control for mic gain that I’m missing in the new version?
