Djay Pro 2! Must GET!
Great Work!
- Automix Resets Tempo to 0% after Mix!
"Morph to have the outgoing track change tempo to match the incoming track ". - Ability to set Bars instead of Seconds for mix transition time!
NOTE, I will edit and add newly discovered features.
