Hi, I have the Numark Mixdeck Quad and a 15" MacBook Pro w/ Touchbar running OS Mojave 10.14.6 I normally use CD’s with both decks and would like to have DJay Pro 2 either as a backup or for main use. I just started the free Demo without connecting it to my Mixdeck Quad. Before I make the connection, I have a few question in regards to using DJay Pro 2;
1) Can any of the controls on my Mixdeck Quad be used when using DJay Pro 2 such as the mixer, volume controls, crossfader, mic/headphones?
2) Is there an option of using an external hard drive opposed to my MacBook Pros internal hard drive? I currently use iTunes in which I have most of my library on an external hard drive.
3) Can DJay Pro 2 be aimed at seperate music folders on an internal/external hard drive?
4) Can music folders be created within DJay Pro 2?
5) My music libraries are in the .AIFF format. Is there any quality loss using DJay Pro 2
I realize this is quite a few questions and in the meantime I will continue to use the Demo along with going through the manual. Once I have these questions answered, I will move forward to purchasing DJay Pro 2. Thank you. Ray
