I am using Djay Pro 2 with a Pioneer SB3. When I am in Vinyl mode and quickly switch from using the top part of the jog wheel to using the sides, the side movement doesn’t adjust my track forward/back. It works fine however if I don’t do a quick switch between top and sides. I attached a video that I hope explains better… Anyone else see this same issue? Is it even an issue or is that the intended behavior?
I tested on two different Macs (one running Catalina, the other High Sierra), so I don’t believe it’s my computer or OS. And I don’t see this behavior in other software (i.e. Serato) using my same set up.
